BlackHat wrote:Quick noob question...
That table is for the advance right? Maybe I'm misunderstanding how advance works... but if I'm reading that table right, 4000rpm at full TP you have 24 degrees advance, but 4000rpm at low TP you have 43 degrees... Don't you advance more on hard throttle than when you're just cruising? And I guess that's the advance + base advance (of 20 degrees right?). That would me 44deg on full TP 4000rpm and 63deg on low TP 4000rpm....
I have to be reading this wrong...
Good question. First, we believe the table is total timing. For advance you minus your 20 deg.
As to the second question - no. Under WOT cylinder filling is more efficient, so you will have higher overall compression. To avoid detonation, timing must back off. However, as the motor spins faster, timing must be advanced. While cruising, there is little chance of detonation so timing advances significantly.
Check this out.
http://members.aol.com/dvandrews/ems.htm
