seang »
https://forums.nicoclub.com/seang-u122444.html
Sun Jan 17, 2010 7:59 am
Also, and this is important, what every D21 owner should frequently do is inspect the front caliper slides (guides) because they can get stuck, and then only one half of the caliper will slide.
It will still work when it's stuck (but not 100%) so it's best to check them, clean them, and lube them generously with synthetic caliper lube.
Don't use wheel beariing grease, the caliper lube isn't expensive, and it just works better for this trust me.
I can pull my lower slides without taking off the tires, it's really easy. Those are also the ones that get hit the hardest by nasty weather, so it works out nicely. Still have to do it, though.
