SneaKe wrote:I'm looking into INVO's, and I like what I see. However, I keep seeing reviews that the sidewalls are soft. My Vredestein Ultrac Sessanta's have very firm sidewalls, and I don't think I could live with anything less. Sometimes the reviewers don't know what they are talking about, but I've seen it said more than a few times.
In your original review, you favored the sidewall of the INVO over OEM. Unfortunately I never drove on the Pilots to have a comparison. Basically, I am very close to purchasing INVOs but am concerned that the quick snap turn-in I'm use to won't compare to the Sessantas.
Any imput on that AZ?
Absolutely, I'd love to comment on that.
A few thoughts:
While I'm unfamiliar with the Vredesteins, I'm not convinced the tread design is optimized for real-world use... I'm sure the designer is well-compensated for designing something attractive, but that doesn't always translate into pure performance.
What I CAN say is this: When I first got my Invos, at approximately 200 miles, I winged a piece of debris on the freeway at 80 mph that catastrophically damaged the shoulder of the tire (rear one, 285/30/20). At that speed, I expected the wheel to be toast and decelerated to the breakdown lane...
I didn't know I had damaged the tire badly, but this is why: Even with a gash the size of a credit card, zero pressure, the rim wasn't in contact with the road - the sidewall suspended the weight of the car even with no air pressure. I was able to limp it home, another 15 miles, without consequence. Likely due to the short sidewall, but I was impressed.
Another consideration is that I ALWAYS run my tires a little higher psi than the manufacturer's recommendation. Of course, the tire manufacturer won't advise it, but you can blame the beancounters and attorneys for that... I learned this WITH the Pilots, in fact.
Always check pressures cold AND hot , and stay within a reasonable range. On a 50 psi tire (such as the Invo), I run around 52-55 hot. Turn-in is crisp and sharp, with no weird center wear, and comfort is unaffected.
