Well, it turns out my knock was a loose pulley, but now I have a different problem.
My car sputters at high RPM or under load. This started when I started playing around with the CAS, though it could be something else. I did a search and this guy had that identical problem, which turned out to be the CAS:
misfire-on-boost-high-rpms-t327535.html
Like him, it seems to get worse the warmer it is. His video sounds like what mine is doing, and my problem is intermittent like his was. The only difference is that mine only does it under load. If I rev it when it's parked, it works fine. According to my wideband O2 sensor, I'm not leaning out
This is what I have and what I've done, none of which have solved the problem
1) temp sensor with 1,000 miles
2) Walbro 255 fuel pump with 2,500 miles
3) VPC (MAF delete) - I set it a little richer and this helped a little, but didn't solve the problem
4) set the timing to 15 degrees with a timing light
5) swapped out the ECU with a code 76 ECU (UKDM) from the code 98
6) bumped up the fuel pressure to 40 PSI
7) replaced the coil packs, ignition module, and dropping resistors with known good spares
8) O2 sensor with 2,000 miles
9) swapped out the injectors with known good spares
What I haven't done:
1) swap out the TPS
2) swap out the CAS
One strange thing that happened when I was setting the timing - I was checking and double checking it (it's kind of fun to play with) and the ignition suddenly retarded. Since I wanted to get the timing right, I did the resistor trick to trick the ECU into thinking the knock sensor detected no knock. This made the timing go back to normal. Right before I started it again, I noticed that injector #2 was unplugged. Can this make the computer think there's knock, or do I have a different problem? I attached a video from today with the engine hot:
[youtube]http://www.youtube.com/watch?v=_L_xGCGOIDU[/youtube]
Does anyone have a good used CAS they can sell me? I don't mind buying a new one if that's what I need, but I don't want to spend all that money just to find out that I have a different problem.
Thanks,
Darian
PS I see these guys are kind enough to sell me a CAS for almost $500. You can buy a whole long block for $300 more.
http://motors.shop.ebay.com/i.html?_nkw ... m270.l1313
