Postby Pslsurf15 » Wed Aug 24, 2016 1:17 pm
As of now, I have an Arduino UNO for my analog to digital conversion. I will be using my raspberry Pi 3 with a 7" LCD touchscreen for the display. I'll try to use the stock wiring for the inputs as to not be cutting everything up. The 3 from the triple gauge should be easy since they are already located in the center. I will run an aftermarket oil pressure sending unit since the stock one isn't the most reliable. This will be a start and then I'll build off this to include more. This is a process since I'm also taking 6 classes this semester but don't worry I won't let this thread die off like the many I have searched for.
