steelcity »
https://forums.nicoclub.com/steelcity-u237717.html
Thu Jul 31, 2014 3:18 am
Let me post an update:
I just finally got the caliper taken care of. The pedal is no longer a sponge. I filled up my brake fluid close to the top so there is no room for air. Then I pulled out a Mageyver move!!
I cut off the tube from an old can of "fix a flat" that I had and I taped it with masking tape to an empty water bottle. I made sure no air can get in there. The tube fit snug right over the valve on the caliper. So I loosened the valve, brake fluid started dripping. I left the bottle hanging there and I went to pump the brake a few times. Got a good amount of brake fluid into the bottle. Before removing the tube off the valve I made sure everything was tight and sure enough....the brake line that goes into the brake cylinder was not tight enough. So I tightened it and removed the tube with bottle. Slapped my wheel back on and took it for a test drive and I had no problem with the pedal. BUT!!!!!!!!! I have a new problem.....
The "Brake Slip" light is on AND the "VDC" light is on. What now?
