If you plan on using the stock idle valve than you just give it ground and switched power. Im using the IACV on the side of the plenum the green solenoid. you can wire it up 2 ways give it power and ground and a switch in between so before you start the car it'll activate the solenoid. Or have MS control it via the FIDLE circuitry, the FIDLE wire on the harness is the signal ground so you have to provide switched power. If going the MS route in Megatune for idle control I believe you use Solenoid as the algorithm.
megasquirt wrote:Idle Control Settings
The basic idea of IAC is that the motor or PWM solenoid starts out with a large opening of the air valve at cold startup, then gradually closes as the coolant temperature rises. The basic motor position at any given time is determined from the input table of step position versus coolant temperature. To this basic control algorithm, several features have been added as described below. You need to set MegaSquirt-II (or MicroSquirt) to tell it if you have a fast idle "solenoid type" valve or a stepper motor IAC, or neither. These are selected under Settings/Idle Control in MegaTune:
If you have an IAC stepper motor, you will have to choose between 'moving only' and 'always active'. If you set your stepper to 'always on' for 15 min or so and it doesn't feel too hot to you, then you can leave it that way. Apparently this is what General Motors does. But if you want to be safe you can test it on the bench for 15 min or so. It will get right warm, but it shouldn't burn your fingers just touching it. If it gets too hot, use 'moving only' instead.
Algorithm (IdleCtl): If you have a:Fast Idle Valve (FIdle): For an on/off fast idle valve, set the algorithm to 'Solenoid'. You can also set your Fast Idle Threshold if you have installed a fast idle solenoid. Enter a coolant temperature to turn on the fast idle solenoid. A typical value is 145º Fahrenheit. The Fast Idle valve will be activated below this temperature (145ºF) and turned off above 145ºF. The Fast idle Threshold is independent of any warm-up enrichment. Fast idle valves generally have one or two wires.PWM Warmup: This is for the Ford or Bosch pulse width modulated idle air valves. Ten temperature dependent levels of PWM are user specifiable if this option is selected (see 'Idle PWM Dutycycle' under 'Tables'). Modifications to the board are required, see this link for more details.Idle Air Controller (IAC): If you have a stepper motor IAC, you can set the IAC Start position, as well as ten intermediate positions based on the coolant temperature to allow a decreasing amount of "extra air" as the engine warms up. These are set under 'Tables/Idle Steps' in MegaTune. Stepper motor IACs usually have four wires.IAC Stepper Moving Only: Powers the stepper only when changes in pintle position are requested. This is the most common type, it holds its position if not powered, and is difficult to turn by hand.IAC Stepper Always On: Powers the stepper at all times. Required if your stepper 'free wheels' when you spin its pintle un-powered with your hand.15 Minute IAC: This operates the IAC stepper motor as 'always on' for 15 minutes, then switches to 'moving only'. This can be useful in some situations in which the stepper moves unreliably if moving only at the lower voltages of cranking and warming up, etc.To select the appropriate 'Idle Control/Algorithm' for stepper motor control in MegaTune you may need to do some testing. In some cases setting the stepper motor to "IAC Stepper Always On" will cause the IAC to get hot. However setting it to "IAC Stepper Moving Only", might cause a problem with idle speed changing from one start to another.
You can test if your IAC is suitable for 'always on' by leaving your stepper powered on the bench for 15 min or so. If it doesn't feel too hot to you, then set it to "Always On". Apparently this is what GM does. But if you want to be safe they should test it on the bench for 15 min or so, or monitor it closely in the car while not moving for at least 15 minutes, checking the IAC temperature frequently with your fingers. It may get warm, but it shouldn't burn your fingers just touching it.
Leave the other values (below) alone, you can experiment with them when you get the engine running.
Time Step Size (ms) (IACtstep): IAC stepper motor nominal time between steps (i.e., 2.5 milliseconds gives pulse frequency of 400 Hz).
Acceleration Step Size (ms) (IACaccstep): not currently used.
Number of Acceleration Steps (IACnaccstep): not currently used.
Start Value (IACStart): The number of steps applied to retract the IAC pintle to 'wide open' at power up.
Cranking Position (IACcrankpos): During cranking, extra air may be useful in the same way as extra fuel in cranking pulses. The table value for the starting temperature may be fine after the engine has started up, but during cranking more power may be needed, especially if the starting temperature is cold. To provide this, you can input a step position that provides a larger than normal air opening during cranking. So, if in cranking and 'Cranking Position' < table value, then the IAC motor position (or PWM%) is set to 'Cranking Position', and when cranking is done, the motor position starts tapering (over the 'crank to run taper time') up to the table value over a user input period, typically a few seconds. (See the diagram below) If this feature is not desired, Just set 'Cranking Position' to a value higher than any table value. Then the table value will always be used since it provides more opening.
Crank-to-Run Taper Time (IACcrankpos): This is the time over which the cranking position of the idle (either the stepper steps or the PWM%) is moved to match the table value (see diagram below). Higher values give a higher idle for longer periods, which can improve starting performance.
Hysteresis (°) (IdleHyst): This input can be used to avoid continuous motor motion (and wear) for small coolant temperature changes. Changes to the motor are only made when new coolant temperature> coolant temperature on the last move, or, new coolant temperature < (coolant temperature on the last move - Hysteresis temperature). What this does is allow constant motor motion while the coolant temperature is rising, but when it peaks, there will be no further motion unless things cool back down - which is unlikely.
Time Based After Start (extended warm-up): You should NOT use the Time Based After Start (extended warmup) option unless you find you need it, and very few will. Disable it by setting the 'cold temperature to -40°F. Then this feature will not be used unless the coolant temperature at startup (ECU first powered on) is below -40°F. This feature is used toward the end of the warmup sequence when the coolant temperature is close to its final operating temperature. In this case, fast idle will normally come off, but SOME cars (very few) may need extended fast idle. An example is a car that uses heavy weight oil, which is nowhere near at operating temp when the coolant gets there, plus a hot cam with not enough idle torque to overcome the oil drag. This feature is implemented by inputting a 'Cold Position' that is the step position at start of extended warmup, typically about 80% of the final, fully closed step position. The IAC behaves normally until the step position commanded from the table just exceeds this Cold position value (either PWM or stepper). From that point on, the steps are tapered in so as to reach the last step value in the table over the 'cold taper time' period. (see the diagram). This slows the reduction in idle air as the engine continues to warm up (increasing the idle speed for longer than the coolant temperature alone would do).
Cold Temperature (°) (IACcoldtmp): This defines the initial coolant temperature below which the afterstart taper will be extended, based on the Cold Position and Cold Taper Time. It should be set fairly cold, generally not more than 20° F.
Cold Position (steps) (IACcoldpos): The Idle PWM values at which time based afterstart tapering is initiated. Note that this value must be higher than the lowest value in your IAC PWM table, or you can get strange operating results.
Cold Taper Time (sec) (IACcoldxt): This is the number of seconds that MegaSquirt takes to move from the 'cold position' to the position indicated in the IAC step table for the current coolant temperature.
