sil80drifter »
https://forums.nicoclub.com/sil80drifter-u622.html
Fri Sep 09, 2005 2:30 pm
oil pressure now at 50psi at 3k rpm, and around 80 at 6500.
This is good enough for me, I'm running 3 quarts of 20W50 and one quart of that lucas oil enhancer stuff (kinda thick and goey but works well I hear).
I have had enough with this low oil pressure stuff, and since anything else I could do to try to fix this problem would be a rebuild, I may as well have fun with the car before I do it.
Compression is at 190 190 200 200 (my compression gauge sucks I think it's really 200 across the board), which means the car broke in well (inspite of my crappy oil issues), so I'm just gonna start boosting her at 6psi (and max out the 270s with the SAFC), and then tomorrow put in the 460s and take them for all they are worth. Around 250rwhp I hope.
We'll see how good I am with SAFC tuning I guess.Oh and I just installed the MSD BTM, which immediatly proceeded to retard my timing without boost (base timing!) so I had to advance it back up, but still running about 3-4 degrees retarded because I'm switching to the 460s tomorrow, and you have to retard the timing because the ECU will advance it when I tune low throttle with the SAFC. You like the run on sentence. You love it. I'll run the BTM at 1deg per pound, for safetys sake. And 93 octane of course.
Thanks for all the help and advice, I'll keep you guys updated.
sil80
