mcrews wrote:George,
Sounds like a great trip.DC is a wonderful experience.I have an 02 F50 and have achieved just over 25mpg on road trips.I stat just over the posted speed limit and try to stay "ahead" of the traffic.I run 255/45/18 and I think my rear end ratio is taller on the 02.
Good luck!
Not very good news I'm afraid.I'm at my brother's in Wisconsin with around 4,000 miles on, very little Interstates. Been to Washington D.C. then to Michigan, and then around the Lake to Wisconsin.Fuel mileage was great for the first 350 miles, around 27 mpg, then for some reason, dropped to around 21 mpg and has stayed there. Might be something wrong. No CEL, but stumbles and hesitates when I floor it from low speeds to pull out and pass someone. Been using premium gas all the way, most of it NON-ethanol blends. 93 octane all the way. Used two quarts of oil so far.
The hum or whine from the rear that no one can diagnose is still there, no worse, but no better. Annoying but apparently not much more than that. I also discovered on the rough roads back East, a loud knock or bang from my steering column on sharp bumps. Add to that a fluttering sound that sounds like it's from the front end. I suspect it might be a tire. Not getting any worse, but also annoying.
After the wonderful trip I made in ,y '94 Q45t 4 years ago, I had high hopes for this trip. I have been seriously disappointed in this car.
When I return home, I plan to write Infiniti and tell them how disgusted I am with this car.
I still have around 4,000 miles to go, and instead of looking forward to it, I'm dreading it.
To make things worse, on the way to D.C., in Indiana one night, I hit a raccoon and damaged the lower lip on my front spoiler and cracked the small black plastic grille on the bottom under the main grille. Probably around $1200 or more to fix.
Not the fun trip we scrimped and saved for, and looked forward to with excitement for the last two years.
I'll take the car into my dealer when I return. If they can't get it fixed to my satisfaction, I'm considering getting rid of it and getting another kind of car.This may be my last Infiniti.
