Up for grabs if the price is right, JDM Silvia S13
Nicksemianiw
Car: JDM 89 Silvia K's
1989 Nissan Silvia K's 5 speed, 160,000 km Lots of upgrades 330-340hp (with boost turned up). Very fast, good on gas when not driven hard. Minor dings from shipping from japan. Just had the transmission fluid changed as well as the oil with filter. NO RUST WHAT SO EVER!! The car has never been tracked or seen higher then stock boost (7 psi) Although it is set up to go up to 18 psi just needs a front mount intercooler and will make roughly 270-280 whp (330-340 to the crank) This is the fastest CA18DET powered Silvia in Ottawa and a lot of time and money has been put into the car invested $14,000. I'm a student and heading off to school in September so I need to sell my pride and joy. And like I said before all the parts are brand new and the car is in perfect order. Just needs new rear tires to cert and passed e-test just last June Will cert and e-test for extra 450$ In the pictures the hot pipe is not on because it wont fit with the stock intercooler.
NOTE: To put the boost up to 18 psi you will need a front mount intercooler as well as a set of GTR 444cc injectors. Other then that its all set up.
$9,600 OBO CANADIAN or $8,300 US
Nicholas
Home: 613-590-9897Cell: 613-263-8834e-mail: [email protected]
Engine-Garrett GT28R turboEqual length turbo manifoldMR turbo elbowMR 3 inch downpipeBlitz Nur Spec catbackGreddy Airinx intake kit with alum intake piping,turbo outlet and inlet.300zx Z32 MAFSBully Clutch Stage 52 1/4 inch hotpipe with couplers
Engine Management-Apex'i NeoHorsham Developments Stage 3 chip
Fuel system-Walbro Fuel PumpNismo Adjustable Fuel pressure regulator
Suspention-Apex'i adjustable shocks and springs
Interiour-Nardi personal steering wheel with hubRazzo pedal kitApex'i Boost gaugeAEM ugo Wide band o2 Auto meter oil pressureauto meter water tempPioneer mp3 cd player
Exterior-upgraded 4500k headlightsGTR front grill
