sl87 »
https://forums.nicoclub.com/sl87-u45393.html
Tue Mar 13, 2007 11:32 pm
Got a MBC and boostin 12 psi on T25. Sometimes when i go full throttle it will hit 12 then hold 11. During this process, at some points of the Rpm, it will do little backfires and bog. I got 255lph fuel pump, 300zx fuel filter. Stock Injectors and FPR. Also, on the way home from work, the turbo was lagging (4-5psi). 10 mins after, started boosting fine. Any opinions are appreciated. Thanks.
