My ? is could an amateur DIYer replace the whole shaft without too much room for error if it needs to be replaced?
The drive shaft is not the problem. If you are lucky, it's just a bod u-joint.Alibireason wrote: ↑Wed May 21, 2025 1:20 pmI inspected my 98 4x4 Pathfinder a bit ago and noticed that the long driveshaft (front end of shaft...pic is looking towards front) has play up and down and when turning it. No right/left play. The U joints don't seem to have play but the entire shaft does...where it connects. The rear end of the shaft has no play. I do hear a whirring sound when I drive that changes pitch with speed. Could this be the cause?
