Drake57 »
https://forums.nicoclub.com/drake57-u87237.html
Sun Jan 10, 2016 10:34 pm
I've swapped MAF to no avail, and it only stalls in gear, and any time it begins to happen if I bump it into neutral, no stall. I've felt lockups sometimes while cruising at 35 to 40, that seemed out of place, just felt like a hard up shift. Also, a live plot of MAF, injector duty, and RPM of a stall (stopped, in gear) shows no indication, no instability in MAF signal. If possible I'll post a pic of it.
AFAIK it's original AT, 150,000 miles. I drove the car for a year or two, then it sat for 4 years after injector failure, I've driven it daily since beginning of December, topped the fluid at that time.
Today I ohm checked lockup solenoid OK, drained and refilled, changed filter, and so far no more stalls.
What's odd is that the connectors at rear of AT were soaked w ATF, but otherwise tailpiece is absolutely dry, it looked as if ATF was being wicked through cable jacket. I do have a plug, plan on ordering several pan gaskets and doing some fluid cycles. Drained fluid had some darkening color to it.
Other thing I noticed while refilling is that I can hear the pump, at lower fluid levels it sounds as if it's sucking air, then as top level is being approached, sound levels out, but still audible. Seems normal? Thanks!
