LoserCard »
https://forums.nicoclub.com/losercard-u78523.html
Mon May 17, 2010 2:49 am
Ok, so I have a new HG, ARP Studs, Reman. Head, and Rebuilt Bottom.
Started up, still pulls, no burning oil.
There is a weird ticking noise that I am still trying to figure out that comes from the rear of the engine.
And when I hand turn my engine by hand it sounds as if air is leaking through the front somewhere... that doesn't seem normal.
BUT! My main dilemma is my 95psi all the way across. Mind you, I did do the compression test after warming up the car.
Aside from the ticking and leaking, why is my compression 95psi across? Timing issue?
Also, could someone post a picture of their cams, chain, and sprockets at the TDC position?
