allenms240 »
https://forums.nicoclub.com/allenms240-u128640.html
Mon Sep 07, 2009 8:16 am
Well both problems have been fixed, but thanks for the info. The A/C problem was just a blown fuse. But is wasn't completely blown so the conpressor would only kick on once ever bump or so.
The clutch problem, was the free play was almost all the way up. The adjustment rod was barely in the clutch pedal. I just adjusted the hell outta it untill i got the desired clutch pedal height as well as when most of my friends have. Thanks for the helo though.
UPDATEUPDATEHey guys,After I had adjused my clutch, one day it wouldnt shift to reverse without grinding a little. So I thought that maybe iI adjusted it too much the night before. So I went to adjust the clutch pedal and now, no matter how far the rod is adjsuted in or out, the biting point in at the tip top of the pedal. This is really frustrating me and I gotta figure this out. I bled the slave and no air came out. I had also noticed that the boot came off the fork, so I i put it back on. After I lowered the car and took it out, still no change whatsoever. Also, the clutch fluid is extremely cloudy, from the CMC it looks black. Any ideas about my problem? Any help is much appreciated
Modified by allenms240 at 8:42 PM 9/9/2009
