Here's an old thread on the subject:
zerothread?id=101111
Wes must have solved the problem, but I don't remember where he posted it. My first thought, of course, is that you bumped something during the oil change, maybe a disconected vacuum hose, or a connector. It's tight in there. Take a good look. Mighty coincidental.
Been doing some searching for you and also came up with this:
zer...age=2
The last post is a diagnosis procedure from the FSM:
"(diagnostic procedure 33. EF-EC 176) and it talks about unplugging the MAF, and then starting and running the engine at 2000RPM for 30 seconds, and if the engine speed drops then its an air leak....
Quote »
1. Disconnect Mass Air Flow meter harness connectors2. After starting and running the engine at 2000 RPM for at least 30 seconds, does the engine speed drop? --------> Discover air leak and repair."
Modified by 96Qowner at 1:37 PM 8/12/2005
