Unusual sound after car is turned off-please help diagnose
1quikta
Car: 2001 Maxima SE 20th Anniversary Edition
Sorry to use my first post this way. I have a 2001 Nissan Maxima SE and yesterday it started making a funny noise when the car is turned off. It it coming from the front of the engine bay and sounds like an electric motor running. The only way to shut if off is to unplug the battery. Could it be the selonoid(sp?) from the starter?I had a SES light come on last week and never got a chance to get it read. I figure it is an O2 since it is running fine, but MPG has not been that good. A friend at work has an 04 Quest and hers did the same thing (according to her) and it was an ABS Actuator assembly ($1,100). I have zero brake and TCS issues or lights.
Any help would be appreciated,Thanks,Chris
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
For some reason I'm thinking ABS relay. Open up the relay box next time it happens and pull the ABS relay and see if the noise stops.
1quikta
Update. The noise quits when the engine control #2 fuse is pulled. The ABS relays and fuses made no difference. Ideas????????????
robo_geek
Car: 2007 Maxima SE
[QUOTE=1quikta]Sorry to use my first post this way. I have a 2001 Nissan Maxima SE and yesterday it started making a funny noise when the car is turned off. It it coming from the front of the engine bay and sounds like an electric motor running.
It's your electronic engine mounts....
http://forums.maxima.org/5th-g....html
1quikta
Yeap, there was a vid on there. Sounds just like it. I will unplug the front one after I get my alternator rebuilt and back in. What are these ES mounts people are referring to?
lightsout
Car: 00 Nismo Maxima SE
i believe the ES Mounts are your Electronic Stability Engine Mounts :-)
NutriaforBreakfast
Car: Nissan Maxima 1995 VQDE engine
Not being insulting here, but an electric motor in the trunktakes down the radio antenna
