rsmithdrift »
https://forums.nicoclub.com/rsmithdrift-u36706.html
Sat Jan 28, 2006 5:31 pm
Hey, guys, I'm new to this forum and I tried searching for exhaust stuff but didn't find what I was looking for......
Anyways, I just bought this nice, clean '93 240sx fastback and it wont pass inspection. I found out that the previous owner hadn't given it a tune up since '95 so I just did a complete tune up on it (plugs, wires, cap, rotor, air filter, fuel filter, and put fuel injector cleaner with octane boost in it) and tried again and it faild again for the same damn reason.......too much carbon monoxide. Monday I'm taking it to get the pcv valve replaced (I'll leave that to those more apt to do it after seeing where it is) but I don't think that'll help much either.
Here's where the exhaust smell part comes in.......I have noticed that even with everything new it still seems to lack power, like something is holding it back for some reason, It runs smooth and idles fine, and has good throttle response, but it just doesn't pull very hard, and I get an occasional surge at 2,500 rpm. Also, I started to notice that the exhaust smell very strong and very bad, I cant even begin to explain what it smells like to you.....best I can do is say that it's like a mix of sulfur water and rotten eggs. You cant smell it inside because the car seals so well, but outside the car and you almost pass out from it. I took it to midas and they said that the catalytic converter was still good on it..........so now I'm just confused.
Why would it smell like that and lack power? I'm sure that's why it won't pass emissions. Whatever it is.
Any help is much apreciated, thanks.
