I haven't tried rolling it on level ground while having it in neutral, no. I will definitely try that when I have a second... But I have put it in neutral while going down the hill for example and the tension/excess drag does disappear/go away.ArmedAviator wrote:It should coast like any other automatic car on the road. You do not sound crazy.
First things to check:
1. Can you put the car in neutral and roll it by hand on flat level ground? Be sure someone is in the driver's seat to apply the brakes just in case.
2. When driving and you decelerate, shift into neutral. Does the excess drag seem to disappear or is it still present?
If #1 doesn't work, I'd suspect a stuck caliper. If #2 doesn't work, it's a drivetrain issue.
I haven't messed around with the manual mode too much, but I'm positive it is not in manual mode when I'm experiencing it. Also, I will have to take a look when I get home to see if I can see any grooves, dust, etc. I'm hoping it is something simple like a caliper as you guys have mentioned. As far as my fuel economy goes, I'm not overly concerned with that as I'm sure I need to get it in for somewhat of a tune up soon. I just figured I'd mention it because... well, trying to think logically about this.. if something is dragging/slowing me down I would assume it would affect my mpg so if I can figure this out maybe I'd solve both my problems.Ilya wrote:Welcome to the forum!
Are you by any chance in manual mode when you're experiencing this 'drag'? This is known as engine breaking and is normal in that mode. If your caliper is seized or sticking, you might be able to look at the rotor and see 'grooves' (it should be generally smooth). Or more brake dust on one wheel compared to the others.
As for fuel economy, really hard to tell you anything without knowing the maintenance history of your car, mileage, etc. Could be anything from spark plugs being old to old O2 sensors to improper inflation of tires to stuck caliper to...well you get the point.
To be fair, there is a certain amount of 'engine braking' when in gear. When you go into neutral on ANY car, you will get a relief of that same symptom. Same on my motorcycles. Motorcycles engine brake probably 50% harder than cars...to the point where I sometimes wouldn't even use my brakes. I would just blip the throttle, drop a gear and let the clutch out and let the bike do it's thing...particular in the city, etc.ArmedAviator wrote:sreve_c, I disagree based on the OP's latest response that putting the transmission in neutral relieves the symptom he is describing. When in neutral, all the other drivel and drag is present downstream (so to speak) of the transmission output shaft.
This is clearly transmission related.
OP, any luck taking video of the issue?
Absolutely true, but the OP seems to have compared this abnormal drag to the engine braking to other automatics. I have driven a G35 before, and while the M35 is a bit heavier and a different final drive ratio, the engine braking/driveline drag shouldn't be increased by an immediately noticeable amount.Ilya wrote:To be fair, there is a certain amount of 'engine braking' when in gear. When you go into neutral on ANY car, you will get a relief of that same symptom. Same on my motorcycles. Motorcycles engine brake probably 50% harder than cars...to the point where I sometimes wouldn't even use my brakes. I would just blip the throttle, drop a gear and let the clutch out and let the bike do it's thing...particular in the city, etc.ArmedAviator wrote:sreve_c, I disagree based on the OP's latest response that putting the transmission in neutral relieves the symptom he is describing. When in neutral, all the other drivel and drag is present downstream (so to speak) of the transmission output shaft.
Still would be curious to see video(s).
Absolutely!Ilya wrote:
To be fair, there is a certain amount of 'engine braking' when in gear. When you go into neutral on ANY car, you will get a relief of that same symptom. Same on my motorcycles. Motorcycles engine brake probably 50% harder than cars...to the point where I sometimes wouldn't even use my brakes. I would just blip the throttle, drop a gear and let the clutch out and let the bike do it's thing...particular in the city, etc....
