PDX_S14 »
https://forums.nicoclub.com/pdx-s14-u32808.html
Wed Aug 09, 2006 12:10 pm
lately my red top sr its running unstable..... it start up fine.... idles fine...but once i start driven and come to a complete stop the rpm goes up and down during idle sounds like i got wild cams up in there which i dont and sometime it dies out too.....after it dies out it will start right back up.....i have searched here and zilvia.net.. ppl said maf, ic piping, leaks, tps , timing , speaks plugs....well i checked all that so where else should i look....... i tested the following items
* MAF putting out 1.5v idle and 4.0v at 4000 rpm* no leaks at the ic piping*TPS its puting out .50v at idle wot was 4.5 or so. and also i did ohm test is less then 1.5 ohm*checked all the vacumm lines no cracks or pinched lines.*timing is right on 15* +/- even took the valve cover off and reset the timing.*CKP is right on the dot*everthing on the manifold and the turbo are tight.*spark plugs are fine its gap at .28 and i chaged them less then 2 months ago.
Modified by PDX_S14 at 4:53 PM 8/9/2006
Modified by PDX_S14 at 2:53 PM 10/13/2006
