LarryStooge »
https://forums.nicoclub.com/larrystooge-u3565.html
Fri Dec 13, 2002 11:36 am
the genius that made it needs to reconsider the direction he points the wastegate, it would be much smarter to point it towards the back of the car, not the block. Theres numbers on it too, and it has a cast finish, not too mention it's at angles around where the runners merge, that you couldn't do without casting (as far as I know). It looks like they took a cast manifold, hacked the hell out of it and placed the wastegate in a crappy direction, and called it a day.It also says their fuel rails are top feed, is the stock one (KA) side feed or something? I guess I could go look, but it's kinda early in the day to be scrambling out to the car, lol. If so, I'd just use some supra 550cc injectors and be done with it.
