240SX Z32 MAF 550CC INJECTORS S14 BLACKTOP (T28)
I have a problem with my Apexi avc-r boost controller, my boost is unstable, I read in the gauge, the needle vary from 10-12 forward and back, I hope someone can help me out this, Thanks.
I FOUND THAT INFORMATION BUT THEY NOT HELP ME SO MUCH
FEEDBACK SPEED :Feedback SpeedIf unstable boost or boost drop occurs during boost control, the Feedback Speed setting may require adjustment. The feedback speeds are adjustable by gear. The higher the value, the faster the AVC-R will try to adjust the boost. However, if the value is too high, oscillation can occur. If the injector signal is used rather than engine rpm, we recommend that this function be turned
MY FEEBACK SPEED IS AT 3 ON ALL THE GEAR
DUTY CYCLE : In some cases, the boost may be unstable, this is caused by a big difference between the actual boost and the boost set in the system
MY FRIEND SAID TO ME TO PUT DOWN MY DUTY CYCLE BUT NO CHANGE ON MY BOOST IS UNSTABLE AGAIN BUT HE SAID TOO MAYBE IS MY ACTUATOR OR MY WASTEGATE IS BROKEN !!
HELP ME PLEASE!!!
