ronin083 »
https://forums.nicoclub.com/ronin083-u92158.html
Thu Sep 10, 2009 7:31 pm
OK, just so everyone knows, I've searched, searched again, then searched some more both on this forum and others so unless you have a link to something I somehow missed please dont flame and post the search feature pic. I'm not a newb I lurk alot resulting in low post count so here goes.
Both my headlights, but mostly the right one, dont seem to turn on unless I punch them. If I hit a good bump it turns them off, obviously not good... I'm leaning towards a short/loose ground somewhere but I dont have a voltmeter and can find nothing obvious. Add to this both headlights are extremely dim and the right one wont adjust it aims at a 45 angle to light up the shoulder. Since I can slap the headlight and turn it on I know its not the switch off the steering column its somewhere on or around the headlight assembly itself. I'm planning on replacing at least the right one with a usdm unit. My questions are as follows:1. Has anyone else had this issue and/or know someone who has?2. Will replacing both units with vertex and/or any other units increase the brightness and if so is it worth it or should I just go to HID kits in the stockers.3. Is it likely replacing the units will fix this or will I probably need to get new headlight harnesses?4. Any other suggestions as to what may be the problem or fix...
ETA: replacing bulbs with brighter ones doesnt seem to solve the issue.
Modified by ronin083 at 12:26 AM 9/11/2009
