MinisterofDOOM »
https://forums.nicoclub.com/ministerofdoom-u16506.html
Mon Apr 23, 2007 9:40 pm
Make sure you didn't unplug anything else.If the transponder key wasn't recognized, the engine wouldn't even turn over, so it sounds like there's something else keeping it from starting.I'm also 99% sure that unplugging the ECU wouldn't cause your ECU to forget your key transponder code. If the code were stored in volatile memory, it'd mean you'd loose it any time the battery died, which doesn't happen.
I'd look for another cause.
