Unplug VTC Solenoid
l0nestar
Car: 1993 Nissan 250SX
2004 Toyota Altezza
1963 Chevy Impala SS
Alright, this seems really noob but, how do I unplug the VTC solenoid? I believe it is the VTC Solenoid (from the diagram in the FSM) It is up, and to-the left of the water temp sensor, black plug with a wire around the base and a red cap. I will post a picture in a minute. I do not want to crack the plug or damage it. This is one of the last pieces I have to remove to get my wiring harness out to remove my engine \ trans tomorrow.
Edit: diagram is on PG EN-122 of FSM.
Modified by l0nestar at 10:38 PM 11/30/2006
l0nestar
2004 Toyota Altezza
I zoomed out for a 'perspective' shot, if anyone had any concerns as to where I am talking about.
wawazat8402
Car: 89 Sil80- RB25DET
get a small screwdriver. like what you use for glasses and remove that wire. start at the sides where you can see the guides. pull those out and forward so they dont lock back in and then pop the wire off. after you get the wire off, the plug will slide right off.
Joe
use a small flathead, dig under the little metal clip and gently pry up.
its a retaining clip. dont loose it. they are a *****.
l0nestar
2004 Toyota Altezza
Done and thanks to both of you!
