vancouverbc »
https://forums.nicoclub.com/vancouverbc-u10923.html
Thu Dec 13, 2007 2:22 pm
Interesting. I have the O2 sensor disconnected from the computer. I can get a reading of .130 if I discconect the two worst injectors. These are the two injectors at the front which are furthest from the O2 sensor and fuel regulator. With only two injectors firing , it is obviosly a lot easier to read lean as two cylinders have only air and the O2 sensor reads lean at low temperature. Disconnecting the two injectors closest to fuel regulator, yields a reading of .55 volts. I guess if I had a base I might be able to make some sense of these numbers.
