Def »
https://forums.nicoclub.com/def-u8646.html
Tue Aug 24, 2004 7:22 pm
Yep, that's my post in there second to last.
With all that said - I did run an Unorthodox crankpulley(solid) on my E36 M3 for a little while, and the engines in those go for a cool $4-5k. I researched everything then accepted the risk. Of course, a set of cams for 8-10rwhp cost over $1k no including install(took factory tools or you crack the cams torquing them they're so long) - so the 8-10rwhp gained from the crank pulley was worth the minor risk.
I just wouldn't run one on an SR that's relatively easy to get power from. I mean come on - are you *really* going to even notice the 4-5rwhp you get from the pulley when you can just add 1 psi of boost and add about double that? There are better places to spend the money, especially given that the stock pulley isn't all that heavy(it weighed about 8lbs on my M3 and was about the 3/4 the diameter of an SR flywheel - i.e. it had HUGE amounts of inertia).
