Unorthodox Pulley
Z_Ro_01
Car: 1992 Nissan 240SX Coupe
hey guysI have an Under drive pulley for my car
Does anyone know the new belt sizes for this one?
On the instructions it shows that the Alternator and the Water Pump use the same pulley?!? and the PS is alone??
Ya.. can someone help me out?Thanks guys
neverlift
go to unorthodox web site for the install instructions.... I dont have a dohc but yeah the water pump/alt are on one and then the ps pump on one then the ac on the last one good luck, btw you might want to replace the front seal while at this.....
Z_Ro_01
Woah waitThe Water Pump and the Alt are on the same belt???They dont line up to be on the same belt?!?
For me its the water pump and the PS thats on the same belt...
hmmm
P.S. I checked the siteStill does not make sense...My water pump is not a Four-Rib???
Someone help pleaseThanks-Jon
neverlift
my bad I see by your avatar your have a dohc.....
Z_Ro_01
Its good man
Thanks for at least trying to help
Can anyone else help?!
93HATCH240
Car: 1993 NISSAN 240SX HATCH
Z_Ro_01 wrote:P.S. I checked the siteStill does not make sense...My water pump is not a Four-Rib???
My belt is 4 rib becuase I have super hicas so the p/s belt is thicker. It should have come with instructions and belt sizes on the bottom of the page. Ill see if I can find the sheet. You might also wanna change your front main seal while you have it off. I can almost guarantee it will leak oil if not changed.
Z_Ro_01
hmm
I think I found the sizes...we'll see if they work
and the front seal was changedyup
thanks
bone_stock_240
Car: 1995 Infiniti Q45
bump for a quick question. I found a guy selling an unorthodox crank pulley that he used on his SOHC. I checked the unorthodox site, and they only have one for the DOHC. Can I assume that the sohc and dohc pulleys are interchangable? Thank you for any help!
Z_Ro_01
I think they are..but im not fully sure on thatCheck ASP, they might have what your looking for?
P.S. Your sig is awesomemakes me laugh every time
turbo2nr
Car: 97 240sx (kouki)
1. for belt sizes call unorthodox.. we recomend gates beltes
2. i dont think the soch is the same as the dohc pullyes..
btw i work for UR.. so im pretty sure
bone_stock_240
Oh ok. I figured it might be the same since there is no part number listed for the SOHC engine. Thanks for letting me know though, I haven't bought it yet thankfully. Maybe I should buy it and try reselling it to an SOHC owner. The guy is letting it go for 40 bucks.
Z_Ro_01
turbo2nr wrote:1. for belt sizes call unorthodox.. we recomend gates beltes
Ok, I think I found it on the site but im not 100% sure
But...if you work for UR, can you just get the belt numbers, you work for them so I would suspect the sizes would be perfect..
Thanks guys
