unorthdox racing claims 37hp gain
Nebraska240sx
they claim a 37hp gain from underdrive pulleys and new belts, is this real or is this just some bs from a supra all beefed up?their pricve for a 240 kit was like $200, but what are the side effects?
Nismo_Freak
Car: 89 Nissan 240SX
Its from a 300Z TT... the KA24DE gains 12whp peak and at least 4whp all over the entire powerband with the full kit.
SRdS14
Car: Workin on my car, chillin with friends, basically whatever...
pulleys???? for real?
Nebraska240sx
what happens when you run them though, i know that they slow the alt down, but do I reall have any thing to worry about?
jemil118
Car: cars,cars,cars
What happens is they run the other belt driven parts a little bit slower(alteranator, water pump, power steering, a/c) This is called parasitic loss. This means that more horsepower is freed up to turn the crank and the wheels. The only disadvantage is that if you have a big sound system in your car that requires a lot of elecrticity, your battery will go dead because the alternator is not able to keep up with your system...If you compare the size of the pulley to the stock one you can tell the stock one is a lot bigger...I beleive there was a thread recently posted about a guy doing the install in General Chat...Also if you are worried too much about your other parts being run slower, you can always buy the entire set. That way your other parts won't be slown down that much.
jemil118
Car: cars,cars,cars
http://www.nissaninfiniticlub....ulley
here it is...
Nebraska240sx
thanks for the info
