SteveTheTech wrote:This system can actually control many of the electronic functions of the AV and HVAC systems.
Now the learning process takes some time (~30-45minutes) but the people who have successfully trained the system and themselves to use it are pleased with the options they now have at the touch of a button.
Steve, thanks,
I have poured over that manual, aa well as the regular owners manual, and still cannot find a way to unlock the commands that are available on Canadian models. That command list starts on page 4-130 of the regular owners manual. The US list starts on page 4-118 and is much briefer. For instance, the only HVAC controls are "Climate Control" and "Climate Control Off". The Canadian commands allow you to set the cabin temperature, or just the driver temp, or just the passenger temp. The Audio commands are 10 times more robust in the Canadian list.
I will have to give the learning function a try, though, as it looks like it at least helps to reduce the number of voice prompts that slow you down.
