There's several programming choices that can be changed, such as doors locking when placed in drive, doors locked at 20mph, doors unlocked when the car is placed in park, etc.Larz wrote:I like the idea that all doors lock automatically after the car starts moving. The only down side is that upon returning home, the doors remain locked until the engine is switched off. Frequently passengers reach for the door handle before I hit the stop button and the doors won't open. Another safety feature if you're hauling rug rats, but slightly annoying to adults.
Door lock function is electronically controlled by the BCM.Debonair wrote:It seems like most new cars are set up this way. I doubt there is any way to change this since it is a mechanical function, not a digital or electric one.
Any way those options are available to us without the dealership? I am mostly interested in doors unlocking when put in park. Like mentioned earlier, passengers often reach the door handle before I turn off the ignition.BlackCat81 wrote:There's several programming choices that can be changed, such as doors locking when placed in drive, doors locked at 20mph, doors unlocked when the car is placed in park, etc.Larz wrote:I like the idea that all doors lock automatically after the car starts moving. The only down side is that upon returning home, the doors remain locked until the engine is switched off. Frequently passengers reach for the door handle before I hit the stop button and the doors won't open. Another safety feature if you're hauling rug rats, but slightly annoying to adults.
Yup, consult is the only way. At least that I know of.Ilya wrote:It probably has to be done via the CONSULT device.
By pulling on the handle from inside?silberma wrote:On my 2016 HL I can unlock the door with the engine running
Correct, but opening the door is a mechanical function (pull handle). When locked the handle's connection to the door release is disengaged. This is why the handle feels like is connected to nothing when it is pulled while locked. The OP's question sounded to me like he wanted the handle to unlock the door which it cannot do, the car (BCM) has to as you said. But I may have misinterpreted what he typed.BlackCat81 wrote:Door lock function is electronically controlled by the BCM.Debonair wrote:It seems like most new cars are set up this way. I doubt there is any way to change this since it is a mechanical function, not a digital or electric one.
Bingo. Just found it.Ilya wrote:It probably has to be done via the CONSULT device.
The Cosult-III is the Nissan/Infiniti factory diagnostic scan tool. Every Nissan and Infiniti dealer service center should have one. A very small number of indepenant shops may have one too. Anyone that has one should be able to change thses settings for you.nnn614 wrote:I'm not familiar with the Consult. Is this something the dealer would be able to do? Or any mechanic with that device?
