unknown wiring problem
S13 240SX
Car: 93 Mazda Miata
i seem to have a problem but i dont know what is causing it with my rb20det..
ok... with my key to OFF and with the key not even in the ingition.
my green relays will start to click every few seconds and when they click it causes the ecu light the red light to go on and off eveyrtime the relays click and it wont stop intill i pull the batteyr out of the car..
has anybody had this happen and know what i can do.
thanks.
craz4240
Car: 1995 240sx w/rb20det
bad ground or power on a ground somewheres man.
PorkChopExpress
Car: rb kouki
has your car been working correctly and this just started happening?
as far as i know your ecu shouldnt be getting power until you turn that key to on. (excpt the backup power to ecu)
so with that info im going to say your feeding contstant power to the ecu and have a loose f3 plug. or whatever plug the s13 have.
S13 240SX
Car: 93 Mazda Miata
not sure but i had a rb wire black/pink going to a yellow/red i think that is what fuked it up. i'm gonna try to re-wire the whole car tomorrow from the chassie to the ecu, to the dash. this is crap
BoostFab
Car: S13cp, S13fb, S14z
S13 240SX wrote:not sure but i had a rb wire black/pink going to a yellow/red i think that is what fuked it up. i'm gonna try to re-wire the whole car tomorrow from the chassie to the ecu, to the dash. this is crap
black pink - > black pink. rewire it is only to correct things; you may encounter and fixes other potential issues. rb20 -> s13 is so simple. do it..
S13 240SX
Car: 93 Mazda Miata
yeah i'll try boostsfed, but its pretty hard for me : ( not easy at all.
