Unknown squeak.
KillaZNA
Car: 1990 NA z32
I have a squeak that occurs at low throttle coming from the front top part of the engine. Starting at 1.5 to 2k rpm. Any idea as to what this may be?
t.mcginley.jr
Car: 2002 Nissan Altima SE 3.5
1990 Nissan 300ZX NA 2+0
1966 Ford Mustang
Loose belts? Is it a squeak or squeal?
twinturbozxtacy
Car: 91 tt
squirrels or chipmunks...
if its coming from the top part it could be the upper timing belt bearing. i know ever since i had aluminum ud pulleys my power steering squeaks once in a while. check to make sure all belts are tight.
KillaZNA
Car: 1990 NA z32
sounds more like a squeal. intermittent.
t.mcginley.jr
1966 Ford Mustang
Ok squealing is usually belt related, unless any of your idlers are old and worn (timing belt idlers or AC idler pulley). You can pop the hook and push/pull on the 3 drive belts to see if any feel too loose. They are pretty easy to tighten, only the PS belt can be a pain because there isn't alot of room to get your arm down there. The AC and alt. belts can be easily tightened from underneath
t.mcginley.jr
1966 Ford Mustang
Also make sure you don't have anything leaking (like PS fluid or coolant) as this can cause intermittent squealing if something drips on the belts.
Ziggy1621
Car: '90 Z32 TT (Shibui)
'90 Z32 2+0 NA
'68 311 Roadster
2004 Rx330
2011 BMW 550i (TT)
twinturbozxtacy wrote:squirrels or chipmunks...
:chuckle:
