MECPInstaller »
https://forums.nicoclub.com/mecpinstaller-u9687.html
Thu Sep 02, 2004 7:48 pm
if the radio was drawing the kind of power to drain the battery, you could turn it on or off while the key isn't in the ign. as for an alarm it takes along time (usually over a month) for the alarm and flashign led of it to drain a battery. You said the chime and interior lights are attached to the circuit, so check and make sure somethign like your trunk/hatch light isn't stuck on or any other lights are stuck on for some reason. The chime, does it work? if its broken it might put a draw on the electrical system but not positive just guessing there.
