SpeedRacer1 »
https://forums.nicoclub.com/speedracer1-u311.html
Sat Oct 18, 2003 4:06 pm
EGR/AIV valve. Remove all of it. Some buy a plug for cheap, others take a dime, and cut the pipe down to less than an 1 inch, then screw it in to keep the heat from escaping. The reason why this part cannot be retained is because it directly hits the steering column. This also the reason any plug needs to be short or else you will have clearance issues.
