Unknown Oil Burning Issue
FourWeeks
Need help diagnosing a problem. My SR is shooting white and blue smoke out the exhaust when I'm cruising, never when I'm idling. Doesn't smell sweet at all so I don't think it's coolant, definitely oil. It will not smoke much at idle or when it's cold, but when it warms up and I bring it to higher RPMs or drive on the highway it will shoot out quite a bit.
I have done a compression test with 140 across all cylinders and a leak down test showed everything was below 10%. I have replaced the valve seals and I got a used t28 to replace my turbo because I thought it was blown. Pulled off my downpipe and there is no oil so I don't think that's the case with this one. I ran seafoam through the throttle body, then through my brake booster vacuum line. It seems to have gotten better but it might just be wishful thinking.
Any suggestions?
lne937s
Car: 2012 Nissan Juke SL AWD
Did you replace the PCV valve yet?
FourWeeks
The PCV valve still has a rattle to it so I don't think that's the issue.
lne937s
even so, considering how cheap it is, you may want to replace it anyway to be on the safe side.
FourWeeks
True
