Unknown objects in hoses on top of rb20
evildave32
Car: 91 240sx rb20det
So i have been tracing a leak in my car (rb20 in S13), and found fluid all over the top of the turbo.Started pulling intercooler apart and there is a substantial amount of oil it. Pulled the tube connecting the maf to the turbo pool of oil in it, took it all cleaned it and decided to check the lines on the top of the block and pulled this out of the first hose
http://www.facebook.com/album.php?aid=3 ... abd66abf1d
any ideas what it is and if it is even suppose to be there. The only thing i can figure is it blocking oil and pushing it back all over the turbo :wtf2:
Carl H
its a restrictor and is normal to have in the factory hoses.
evildave32
How about the little wire brush? And should i keep the restrictor in it
Carl H
uh...the wire brush shouldnt be there but the restrictor should be kept.
and sounds like you have a blown turbo if its leaking that much oil.
Genpac
Car: '93 240sx RB20DET 'vert
Carl H wrote:uh...the wire brush shouldnt be there but the restrictor should be kept.
I beg to differ, that wire brush and restrictor is factory and is in the USDM driver's side V/C vent hose that's connected to the air intake hose that connects the turbo inlet and MAF.
Carl H
really?
guess i never noticed the brush...weird.
proly there to help condense oil vapor.
evildave32
so should i put it back in there?
evildave32
And as far as the oil in the intercooler pipes ,Carl my turbo still spools at about 2 grand no weird noise from it and i checked for shat play and there was none what other way would a jacked turbo act?
240cp
Car: 95 240sx
Pretty sure he was talking bout the oil in the intercooler. Like bad front seal.
