The whole SAE Baja competition works like this: Pretend a company has just contracted your team to design and build a one person mini-baja car prototype to be mass produced. The engine is limited for all teams to a Briggs and Stratton 10hp engine.
There are all kinds of rules and regulations that it must meet (roll cage, safety, etc) and it must be cost efficient. We have to actually turn in a cost report that shows how much our car would cost to the retail consumer (we include EVERYTHING. Inches of weld, labor time, parts, fabrication time, material, etc) and we get points on our cost efficiency. So you cant just go out and over engineer the crap out of it and say "We built the best car." There is also a design report that we turn in that includes all of our design decisions on each part of the car.
Then finally we build the car from the ground up and take it to competition where we race it. first they critique our car (cost and design), then we do isolated events like hill climb, acceleration, braking, cornering, and rock crawl, and then there is the 4 hour endurance race. Our current goal is to finish the endurance race. A whole lot of teams break their cars before that race is over, so finishing is a good accomplishment. We're a smaller team with a budget that is smaller than some team's travelling budgets, but we make it happen and have gone out to competition every time we've tried. This is my first year being on the team, but its been pretty active for the last 5-6 years.
Anyway, its crunch time and the car is actually starting to look like a car. Here are some pics from start to present:
This is where it started, our materials arrived from EMJ metals in Eads, TN. They donated all of that to us!
Here is our "Tiger Baja" shop. This is where the magic happens.
We started by building the front "bulkhead" of the car. We got a JD squared tubing notcher that makes these notches super easy.
From left to right, Me, a member named Arjit, 2011/2012 Tiger Baja car, and a member named Christian
We eventually convinced the right people to let us put the old Baja car in the Engineering lobby. We took the front end apart and then re assembled it between those pillars. So its going to be hard for it to "disappear."
Here is the front bulkhead being tacked together. Thats Zain, our team president, running some practice welds before tacking.
Then we began the firewall. We couldn't make those bends you see with the tools we had. So we took it out to a local shop called Racing Eclipse Technologies and they did it for us. That shop is AWESOME.
Putting together the jig for the firewall
Here it is jigged and tacked
Then we connected the bulkhead to the firewall
After that was tacked, we started the roll cage.
Zain putting down more tacks
The main frame and cage complete.
It closely resembles one of my favorite helicopters
After spring break, our seat, steering, and BMC setup arrived!
We notched a bunch of tubes to start the rear end of the car
And it began.
Then on to bracing and mounts!
My stare of approval.
I went into beast mode when I was notching tubes.
Arjit checking out the car's butt.
RLCA in the making.
I'd like to think I'm getting pretty good at MIG.
Sick discoloration on a freshly welded rod-end insert.
FLCA mounted. We actually bought the FLCAs straight from polaris and then modified the shock mounts on them to fit our application. worked out well. Look at those sick control arm tabs! An awesome sheet metal shop, O.H. Hendricks. The hooked us up big time with free sheet laser cut sheet metal parts.
More laser cut mounting tabs
This is one of the sexiest pieces on the car. Its our drivetrain mount. One of our team members (Arjit) designed that lower portion. That is actually where our trans mounts, and the engine will mount on a plate on top of it. All aluminum and cut by none other than O.H. Hendricks. Its such a freaking sexy setup.
And heres the car doing a pushup.
That is it for now. Paint goes on today! I'll post up more pics as I take them (and when I have time). I've been working 12 hours or more a day on this thing with the rest of the team. We pulled an all nighter and worked 24 hours over the weekend haha. Hopefully its all worth it!
