kclo4 wrote:...
In general there are always certain mods that cost less than other for the same power gain. In the upgrade process the cheaper ones are usually done first of course.
I guess with the custom setup I want to try I will find out if I can make more than 10HP per $100. I think it will be fun to try though.
Umm where did you pull this information out of?... your buttocks?.. in the upgrade process of a person with experience, the most expensive mods are done first.. usually being a turbo setup, or something of that nature.. THEN the cheapo mods are done..
tell you what, if you send me 100$, ill give you a fake dyno that shows you gained 10 whp.. per 100$ you send me, will add 10 hp to the dyno... that is the ONLY way you will gain 10 hp per 100$.. because if there was a way we could get 10>100$, believe you me, it would have been done by now
