universal fogs
dom_cull
Car: altima coupe 2.5s
hey guys...im looking into buying fogs, i was at the store and i saw these fogs that i really liked but the only problem is that i dont know what size would fit the coupe. can any one help me out?
Blackmobile
Car: 2008 Altima Coupe 2.5S Super Black
if you want to see if they'll fit, then measure the fog light hole in your bumper and make sure the fogs you want to buy will fit inside. i think our fog openings are about 3.5"
also, when you're buying non-oem fogs, make sure you check to see if they're "rear mounted" or the type that just sit inside the fog hole enclosure. any fogs that are "rear mounted" pretty much need to be OEM, because our fog openings are on an angle, so if you mount them flush with it on the bumper, they'll be pointing in the wrong direction. my advice: go with OEM, they're around $200 on ebay, if you go OEM you won't regret it, whereas if you go with these "one size fits all" types, you might.
