Universal Air ....
mrmark
Well the system is in.....
My installer did one hellova job with the install !!!
We ran a dual compressor setup with a single 3 gallon tank. He managed to hide all components behind the front and rear bumpers including the tank and both compressors. When the bumpers are installed, there are no visible signs of the system. Even the lines going to the rear are not visible under the car.
When I get the bodykit pieces back from the shop and reassemble it, I'll post pics...
http://s16.photobucket.com/alb...1.jpg
http://s16.photobucket.com/alb...9.jpg
http://s16.photobucket.com/alb...0.jpg
http://s16.photobucket.com/alb...2.jpg
http://s16.photobucket.com/alb...5.jpg
http://s16.photobucket.com/alb...4.jpg
Eyedea
This has to be one of the cleanest UAS install job i have ever seen. cant wait to see the final pics
auditech10
Car: 03 M45
Looks great! Another set of tires with a little bit more of a stretch and some camber would let you get a bit lower, I bet.
mrmark
Tires do not rub anymore...I went with a 245 on the back since the 255's rubbed.
auditech10
Car: 03 M45
Ok, I didnt know that you switched them already. It look like in the pics that they were a bit too close to the inside of the fender.Cheers
mrmark
....finally took a few pics. This is all the way down...not quite as low as we expected, but low none the less.
http://i16.photobucket.com/alb...2.jpg
http://i16.photobucket.com/alb...4.jpg
http://i16.photobucket.com/alb...5.jpg
(V)erciless
Car: 2003 Brilliant Silver M45 1985 Black 300zx NA to Turbo
Gorgeous!
What is your offset and rim size?
mrmark
Thanks...
Currently I'm on 20x9 +22 and 20x10 +22. I may try to go 3-5mm more aggressive in the back.
caug1
Car: 03 M45
http://s16.photobucket.com/alb...9.jpgHi Mark, what type of mufler you got there?is it just mufler or entire cat back set up?i got straight pipes in between the cats and stock mufler. how loud will it get if i just use your type of mufler? and how much for the mufler?can you post some sound clips, please.thanks,caug.
mrmark
caug1 wrote:http://s16.photobucket.com/alb...9.jpgHi Mark, what type of mufler you got there?is it just mufler or entire cat back set up?i got straight pipes in between the cats and stock mufler. how loud will it get if i just use your type of mufler? and how much for the mufler?can you post some sound clips, please.thanks,caug.
The muffler is a Junction Produce.....rear section only, but we had to build a collector because the Jspec muffler only has one inlet.
Since the US Y34 has pre-mufflers, the sound is no different than stock. I even ran the car without any rear section at all, the sound was no different.
mrmark
jadeM45
Car: Pending
What was the cost of the kit installed? Looks great by the way.
auditech10
Car: 03 M45
With all marks sponsors and friends it will be a lot less than what you would pay for it....
