unidirectional tire
nyckanny
hi, I have some really old tires, where the side wall lettering is basically illegible. They seem to be unidirectional, is there a tip to look at the tread pattern and predict the direction. Or is there some sort of test?
thanks!
corn322
Car: 1993 240sx
if you can make out an arrow that shows direction of rotation, it's directional.
also, directional tires usually have an obvious "v" pattern to them, at least all the ones I've seen.
chmercer
if they are so old that you cant read the sidewall, they shouldnt be seeing street use. throw them away
szh
Car: 2018 Tesla Model 3.
chmercer wrote:if they are so old that you cant read the sidewall, they shouldnt be seeing street use. throw them away
Very true!
Tire rubber is unsafe after four to five+ years. Can crack easily - at speed would be dangerous! Check the mfg date code (if you can see that!)
Z
nyckanny
yeah, i guess the load capacity of the tire just isn't the same anymore,thanks for the help.
but usually the v grooves in the tread roll in the dirction where the bottom tip of the v hits the ground first as the tire rolls, right?
8^P
szh
nyckanny wrote:but usually the v grooves in the tread roll in the dirction where the bottom tip of the v hits the ground first as the tire rolls, right?
Correct!
Z
