I tore it apart....only to find that the side seals, bearings and input seal are not the standard 240SX set. OK, can't be that different (My stupid inner-voice says).
The pinion seal is a G_D Unicorn. Found only in Japan...and it's pricey (50-60 bucks). The Axle seals....took two days and three AI's (GROK, Copilot and Gemini) all working together (pasting each AI's answers and logic into the other AI input box) to help track them down. My lord....what a rabbit hole!!! It was like herding cats. AI's will never take over if they can't even figure out Nissan JDM parts
The bearings, I thought Id try checking the "Intar-webs".....yeah...wrong answer. Several people who "knew it all" sent me down a rabbit hole. Two hours later, I ended up trudging out to the garage to read the numbers from the bearings. Should have just done that from the start and saved the brain cells I suppose. The bearings ended up being about same price as the 240SX bearings. FCO bearings had dozens in stock.
In the end, a successful rebuild, and happy with the results. Problem solved.
Anyways, is there a Unicorn parts thread to post the hard to find stuff to save people time? If so, I'll list out the part numbers, sources, and any tidbits to help the next guy.
Mark
