j-z wrote:the whole car is a unibody design. no full frame and a body mounted on top of it, just a bunch of sheet metal welded together. thats why unibody cars are such a ***** to fix when involved in major collisions. its like one big ****ing metal puzzle.
It can be a pain. But in some cases a frame pull can undo a large portion of damage. It still may require some manipulation and light body work though. When sheet metal buckles because a frame is bent is a typical case where this occurs. Depends on the extent.
And Unibody frames have a big safety advantage pound for pound. They distribute impact energy throught the body along mulitple paths. It's not uncommon to see frame damage in the rear of a car in a major frontal impact. A body on frame only distributes impact energy through the frame itself. And these tend to be fairly rigid so the impact energy usually stays localized to the area of the impact. In heavier impacts, this could result in the passenger area being compromised more than it would in a unibody frame. Though body on frames are usually more typical of SUV's and trucks which tend to have more weight and sit higher than passenger cars. So they tend to be safer from that standpoint, but pound for pound are not as safe as a unibody car(generally).
