Hmmm, I actually did'nt think of that. It's not venting anywhere at the moment. I've capped the valve cover. So you think I should make some kind of oil catch can? If so, here's a pic of my engine bay so maybe you can suggest the best way to run it and where it's supposed to connect to.C-Kwik wrote:so where is the crankcase ventilating to? If it's sealed completely, it will pressurize the crankcase. Not a good thing. You could end up with leaks at many seals. All of which can leak oil with it. Some can be internal and others can be external.
A breather will work, but it is actually designed to see some vacuum. This helps keep crankcase pressure slighty negative which increases power and fuel economy ever so slightly. If you are not going to use a breather, and actually route it where it should be, then you'll want it to plumb back in just before the turbo. Using a catch can is not necessary, but not a bad idea either. Whatever you do, don't plumb it in after the turbo or you will pressureize the crankcase severely under boost.side waz wrote:
I just want to solve this problem and I hope it's not to late and I've done some real damage inside. Now I have'nt really been hard on it at all since I have'nt hit the dyno as yet. I go a little in to the boost but never over 5K rpms. I shift prior to that as the car really leans out at that point.
Anything you can recommend would be greatly appreciated brother.
Well, he's not seeing any smoke. And oil can easily leak passed the valve stem seals under pressure. Worn valve stem seals generally leak the most under heavy vacuum(intake manifold) and puddle oil which gets burned out all at once when you open the throttle and force it all through the engine or during idles if the oil can drip into the combustion chamber from there. In this case, you burn a lot of oil for the amount of air going through the motor, so the smoke becomes visible. If you are cruising then it's possible you may be burning the small traces of oil with enough air so that it is not visible.koukiKA240 wrote:Though i would highly recomend getting a ricer filter for the one on the valve cover i dont think having that pluged would cause your smoking problems.~Sam
