unexpected upgrades
ch187
Car: 90 CA 240sx
so my maf went out yesterday, along with with my ****ty stock turbo. i guess stock ecu with 12psi and atm. bov was too much. i wanted to upgrade ive just been putting it off now. but i kinda have to now. so i had planned on getting z32 maf, s14 t28, 450cc dsm injectors, recirculating the bov into a hard intake pipe. walbro pump and nismo fpr. and a rom tune.
will i need anything else?
im not looking to get a certain whp number just to get it running, i'll worry about that later.
with 450cc injectors, what hp do they max out at?
if i get a rom tune, is it necessary to have an safc/wideband? i wont have the cash for it right now
bias
Car: 89 240sx hatch 93 240sx coupe
From what I've heard if you mod your ecu you would be good but you may be stuck with those upgrades. I plan on doing similar mods but I was thinking of going with megasquirt II stand alone management. I checked it outand it's one of the coolest things I have seen. You have complete control over everything. You don't need a MAf or the stock coil pack,and you can make what ever changes you want and tune it yourself with a laptop. It may be more expensive in short but the long run would be worth it since you don't have to morry about all the expensive replacement parts. Check it out in the stickies for upgrades. Not to mention you could sell the stock parts to help pay for the set-up.
ch187
Car: 90 CA 240sx
im very aware of MS i just dont have the time or money for it. 300+ compared to the $10 it costs to burn a chip and socket my ecu..i would love to go MS inthe future and i probably will
ca18datsun510
Car: bmw 330i zhp, 91 infiniti m30, 89 240sx, 07 zx6r, 05 trx450r
i sold off stock harness, mafs, coil packs, injectors etc, and got enough to cover ms
ch187
Car: 90 CA 240sx
still i time issue. i have no time at all to get it running again. its costing me more to have it sit then to actually drive it.
rico05
Car: 1992 RMS13 w/ CA18DET
bias wrote:From what I've heard if you mod your ecu you would be good but you may be stuck with those upgrades.
Nope. You socket the ECU so that you can just snap in different EPROMs as you need to retune. Not the easiest way, but it sure is cheap. I just rechipped my ECU for less than $20, and that was because I had to have someone else do my EPROM for me (thanks bio!!)
Also, look into the Pocket Romulator. This is more than likely what I will do.http://secure.transtronics.com....html
Nunook
if u get the ecu tuned then u will not need a safc. As long as the person that tunes it for u does a good job. If u can 550s then that should be enough fuel to max out the turbo. Thats what I plan on doing. I just need a few more fittings.
If ur serious about keeping the stock harness and ecu, then u can get one of the Nistune boards. They come with obd1 for the ca, and realtime readout/tuning. Alittle expensive $375 i think but worth it to me.
And assuming u have a FMI, you should be good with all those parts. Goodluck.
ch187
Car: 90 CA 240sx
exactly. you know what im talking about. who did you get to burn your chip? i dont feel like buying a programmer just yet and definately dont have the money for an emulator. yet.. thanks for the response.
240sxbobbis
Car: owned a ca18det s13 two of them, jeep wrangler, suzuki gsxr600, 86 mazda rx7, and a y33.
uhhhhh ill go with the power fc how do u go about rechipping ur ecu though kinda want to know. whats it all about is it good indifferent anything more? who does this ?where ?how much ? when?
ch187
Car: 90 CA 240sx
i would serach around for that asnwer because theres about 2 hours of reading just understanding what you have to do. basically theres a computer chip in your ecu called an eprom chip, i controlls your fuel and ignition maps by altering those maps you can compensate for larger mafs and turbos and such. its cheap if you tune it yourself, theres even tunes already posted.
and i would like to go 550cc but i can get basically brand new dsm's for 120 shipped. i guess i could find some rx7 ones. how much power do they max out at? what 300whp? thats more than enough but would be nice...
240sxbobbis
thats basically the approach i want to go for alsoonly 300 and im fine
ch187
Car: 90 CA 240sx
then honestly power fc would be a waste of money. spend it on suspension
rico05
bio burned my ROM, but he kinda did it as a personal favor, so I'm not sure if he will do too many more.
240sxbobbis
hmmmmmmmmmm.... ok i mean it wont hurt to ask right?anyone?
ch187
Car: 90 CA 240sx
yeah i figured. i gotta find someone with some chips and a programmer. i dont feel like buying one. well i want to i just have other **** to get.
