Uneven tire wear
InsanityInc
My front tires seem to wear out extremely fast on the outside edge. The rears wear evenly. I drive harder than your average joe, but not anything extreme. What should be done to correct this? Do I need to add some front negative camber?
sean8564
Car: 1993 Nissan GT-R V-Spec
1991 Nissan 300ZX TT Black
1993 Nissan Silvia
1990 Nissan 240SX Coupe RB25DET
You need and alignement best to get a four wheel one.
InsanityInc
Well, supposedly I had one when I had my tires installed, and they're fairly new.
sean8564
1993 Nissan Silvia
Did they balance it or Set it up on a rack and took a hour or so under your car aligning your car up.
InsanityInc
sean8564 wrote:Did they balance it or Set it up on a rack and took a hour or so under your car aligning your car up.
No idea. I was at work.
C-Kwik
I'd get a second opinion. Perhaps someone with a manual alignment machine. A race shop would probably be best, but can be a bit pricey. But they would take more care in making sure it's aligned to a tighter tolerance. You're typical mechanic or tech only tried to get it within the factory tolerances. While this is typically fine, if they've done a poor job setting up the car on the alignment rack, then the computer can show it in spec while it actually is not.
Even with hard steet driving, I wouldn't expect to see any significant wear on the outer edge. Using it on a race track is a different story.
1991S13
Car: '91 240sx Coupe, '00 QX4 4x4, '02 Sentra Spec V
If you can't get the alignment right away you might want to get the tires turned over so the inside edge is on the outside now.
Or just bring the back tires to the front.
InsanityInc
1991S13 wrote:If you can't get the alignment right away you might want to get the tires turned over so the inside edge is on the outside now.
Well, one of the fronts popped, so I had to replace them anyway. I figure I can get an alignment soon anyhow.
