That's too much difference. Have you hit something before? Something's bent bad. If it's small difference, I would think worn bushings or slight bent will cause the problem, but 1 and 3 fingers? That's just too much.jkerr240 wrote:well its to dark now to measure but i can get one finger in on my drivers side and 3 in on my passenger side so thats kinda a big difference lol
Try to push the car, make it up & down, let it settle, measure several times and see. You have sway bars, so height changes as weight shifts left and right. Your suspension is not stable.jkerr240 wrote:ok the weirdest thing just happened today. i went to check the space situation and the driver side is now 3 fingers and the passenger side is 1 to 2 fingers when the other day it was oppisit i have no idea what to think now? ne ideas
FSM shows all the numbers you need.jkerr240 wrote:well as long as its as close to spec then i wont worry about buying aftermarket because i dont have the money. lol maybe ill go to another shop and ask them to measure, unless someone knows the measurements?
