Uneven Suspension
DrJuice164
Car: 04 G35 Coupe
Well its been maybe a month or 2 since i put in my sportlines on GR-2's. I figure that was long enough for them to settle, but the problem is the front driverside and rear pass side sit lower, how i dont know, but the wheel gap is noticalbe different from the other two wheels. There realy anything i can do besides just leave with it and move on?
seyath
Car: 2004 Maxima SE, 6sp, black leather. 1991 240SX, 5sp, grey leather.
Well, don't expect the GR-2's to last too long on Sportline springs. GR-2 shocks were meant as a direct OEM replacement with very similar quality, so you are basically running stock struts on lowering springs. If you drive like most of us do ( ) then don't expect them to last too long. My suggestion, deal with it for a while and get yourself some AGX's or Tokico Blue's. Now, if you don't drive hard and they are running very uneven in only a couple of months, you might want to check if during the installation everything was adjusted and tightened properly... You might want to check your bushings too.
