Uneven mufflers
Defyantt
Car: 2015 Infiniti Q70
Hi All
I noticed the muffler on the driver's side is lower than the passenger side. I googled about this and seems somewhat a common problem on other vehicles in addition to Infiniti. Is it because the muffler is settling due to the heat? I brought it to the Infiniti service center and it was a complete waste of time. They claimed I hit something and that is why it is uneven. Does this have something to do with the metal bracket and the rubber piece within? What is the best way to correct this issue?
Replies appreciated,
Thank you
Ilya
It might be the rubber has gotten loose/stretched from being exposed to elements...
Defyantt
Thanks for the reply Ilya
Debonair
Car: 2011 Infiniti M56
If they found physical damage on one side they could be correct. A bend or kink in the system could cause one side to be lower. If there is no damage, I'm with Ilya. Rubber weakens and stretches over time.
Defyantt
Thanks Debonair!
